looking at cc-fom25 carbon forks but is it available in non tapered steerer with IS brake mounts also would the cc-fom25 model work with standard 1/18 headtube and if so what headset to use
by tyddyn1956 Wed Jun 11, 2014
For a similar type fork to CC-F0M25 with a IS mount please look at our CC-F0325 fork.
Please contact the frame manufacturer for more information on the type of headset you need.
If you are only replacing the fork, then your existing headset would suffice.
Regards
Support Team
by support Fri Jun 13, 2014
gone for the foe390 post mount my bb7 mec disc brakes should fit ok
by tyddyn1956 Sat Jun 14, 2014
Thank you for your message.
We will now process your order for dispatch
Thank you for your custom and we look forward to be of service to you again soon.
