Disc brake catching
I have a new bike with disc brakes. The front brake seems to be touching something once every revolution. However, when I touch the brake lever the catching stops. It is almost as though the brake pads have some slack or play in the caliper and they are touching the rotor. As soon as the slack is taken up by touching, not pulling, the brake lever the noise stops. Can anyone relate to this and explain how to remove the 'slack' on the pads and hopefully resolve the problem?
Please help.
I didn't find the right solution from the Internet.
References:-
https://www.bikeradar.com/forums/viewtopic.php?t=13085250
Infographic animation company
by johntimber     Wed May 09, 2018
