I would like to buy one of the Cobra's (or other seat posts at your suggestion) but need to confirm my 210lbs will be OK with this model. I have bent my current AL Seat Post, its 27.2 @ 350mm so want to replace with something thats stronger for my XC riding.
Would you recommend the Cobra or one of the others, weight isnt a factor, but strength is.
G |
by g00f Sun Jun 20, 2010
The maximum rider weight limit for the Cobra seat post is 100Kg / 220Lbs.
As you would expect, all our seatposts are tested and certified to International Strength and Safety standards.
The Cobra is a great seatpost and the full monocoque design makes it very strong indeed, as well as making it look fantastic. Recommended!
Thanks |
by support Mon Jun 21, 2010
Thanks for quick reply and information, I placed my order this morning for one. . |
by g00f Mon Jun 21, 2010
Hi Support,
Question:
My current post is AL and my Frame is Ti, so a bike shop told me to grease up the post to keep it from seizing together, so my tube has grease in it.
When I get the new Carbon Cobra Seat Post, should I clean it totally out and just place the NEW Cobra in, make sure there no grease left in the Seat Post Tube? And I read that I need to make sure that the Seat Post is at least 8.5cm in the tube, is that correct also.
thanks
g |
by g00f Mon Jun 28, 2010
Throughly clean your seat tube and seat clamp with a degreaser or at least make sure there's no more trace of grease. Dry it clean with a clean cloth.
You don't need any grease or whatsoever when installing a carbon material product, it will definitely slip if you apply grease unto it.
If you die do wanna use some sort of a paste on your seat post or any other carbon part than try to get carbon paste like in Tacx Carbon Assembly Paste. |
by Zeppelin Mon Jun 28, 2010
Thanks Zeppelin,
I figured as much, and thought there would most likely be an issue, but just wanted to know how much to clean, and looks like its good get a full cleaning to make sure nothing is left. I'll start cleaning it now.
Much appreciated,
g |
Hi g00f
Your order was shipped from our warehouse in the US using the USPS Standard International Air Mail service on 23rd June. It passed through the US customs as item number LJ025446536US. Please note this is not a tracking number. It should reach you soon.
Thanks for your custom |
by support Tue Jun 29, 2010
