26" wheel & 180 rotors on 29er fork?
My current suspension fork is 465mm axle to crown and I always ride it on my commute locked off so there is no sag. Can I fit a 29er carbon fork to 26" wheels to keep my frame geometry? Also would 180mm disc rotors work ok?
by faribaldy     Tue Mar 23, 2010
The 29er forks would be suitable if you're running disc brakes.
If you're using V brakes choose CC-F0265-26 which has the v brake mounts positioned for 26 in wheels. CC-F0265-29 is the same fork with the v brake mounts positioned higher for 29er wheels.
We recommend 160 rotors.
by support     Thu Mar 25, 2010
