Matrix II seatpost
Hi Guys,
I was wondering if you could tell me the minimum insertion length on the 350mm seatpost please. I've got a feeling I'll need to run it at full length unless you happen to be releasing a 400mm any time soon?
Cheers
Phill
*Just found an answer to a previous question on 300mm seatposts, I assume that the 350mm are the same 85mm min?
by monkeyfiend     Fri Apr 09, 2010
Yes the minimum insertion is 85mm.
Some models of 400mm length posts are due to be available later this year.
There is no date fixed for their release at the moment.
by support     Sun Apr 11, 2010
