Bought a pair of carbon fork & the superlight top cap. The problem is that the design of the top cap is such that it means that it is impossible to get any preload on the headset bearings. |
by Mark Elvin Thu Jun 24, 2010
Can you describe the difficulty you are having please. The product is intended for this use, has been thoroughly tested and is even patented.
Thanks |
by support Fri Jun 25, 2010
The cap will not allow any preload to be added to the headset/stem, the part that is supposed to grip the inside of the dteerer simply slips up the steerer.
I have now bought an FSA one, at a cost of £13.95 an it works perfectly.
The design of your component prevents preload being added. |
by Mark Elvin Fri Jun 25, 2010
No additional comment support? |
by Mark Elvin Fri Jul 02, 2010
We havent come across this problem before. I have tried it myself & it worked fine. If anyone else has had a similar problem, please let us know.
Thanks |
by support Fri Jul 02, 2010
support wrote: | Hi
Thanks |
I can assure you it doesn't.
I am a design engineer for a top F1 team and the mechanics of this parts are all wrong if it is ment to act in the same manner as a star nut. |
by Mark Elvin Wed Jul 07, 2010
Well, if you are a design engineer for a top F1 team (which one?) I wont argue with you, and it is nice to know that you like our products (except this).
On the other hand we still havent had anyone else come back to us or post here to say they have a similar problem.
We will keep an eye on it though
If you still can't get the product to work, please send it back for a refund.
Thanks |
by support Wed Jul 07, 2010
