Rider Weight limits and carbon forks
Hi ,
I weigh around 95kg , then with gear maybe 98 or so.
What are the weight limits for the exotic rigid carbon forks ?
would I be too heavy to safely use ?
It will be mostly for road use on converting an old hardtail to rigid with slicks.
My current suspension fork is 500mm A2C , I think Ill try get a rigid fork around 465-470 in length
thanks ,
J
by jambonsambo     Thu Feb 27, 2020
Thank you for your message.
Our recommended rider weight limit is 97.5kg (215lbs).
Thank you for your interest and I look forward to serve you soon.
Rebecca
by support     Fri Feb 28, 2020
Thanks ,
What about the aluminum forks ? I assume the limit is a lot higher , maybe better for me .
by jambonsambo     Mon Mar 02, 2020
Our manufacturers guarantee for rider weight limit on Aluminium Forks is also 97.5kg (215lbs).
Thank you for your interest and we look forward to be of service to you soon.
Sui Ping
by support     Fri Mar 06, 2020
privacy | terms | blogSpecifications subject to change © Copyright DiscoBrakes.Com Pte Ltd 1999-2025
