Rigid fork to replace 120mm sus fork
i have a 80mm - 120mm travel front suspended hardtail. what length of rigid alu fork do i need?
by midst88     Tue Jul 03, 2007
In that case you could go for the 29er fork 46.5cm. If you're running your suspension fork with quite a bit of sag, you may prefer the 44.5cm length. Either will work fine for you.
by support     Tue Jul 03, 2007
